Assuming a dry sleeve engine, the differences in size in sets like these are not very great. When installed, the size of the block bore, and its press fit relationship, will squeeze the sleeve more than this variation. The machinest will fit the pistons if needed when installed. If they are fit to the eleeve, it would still need clearance check befor being buttoned up. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
