Re: antifreeze
Posted by Janicholson on February 23, 2008 at 16:39:35 from (72.25.161.218):
In Reply to: Re: antifreeze posted by Tony S. on February 23, 2008 at 16:32:07:
They do not evaporate to cool. The radiator removes drastic amounts of heat, cooling the Coolant, so it sinks to the bottom and enters the block. ThermoSiphon. The old timers used alcohol in the water to prevent freezing. It did evaporate, but not because it was intended to, but that it was unavoidable. Put 50/50 mix in it and keep down corrosion. no problem. JimN
