Cub hydraulic noises, zings, and hoses jump
Posted by mkirsch on February 24, 2008 at 08:23:10 from (72.226.216.69):
I installed a bypass block and a single spool valve on my Cub for a loader.
The hydraulic reservoir is full and I attached an external reservoir that's also full and located above the gas tank.
Now even after running the tractor for about an hour, I'm still getting noise from the hydraulics every few seconds: It's a very distinct "ZZZZZZZINGGG!" noise, and the hoses to the spool valve jump.
I've been avoiding the issue for a while, but spring's coming and any ideas what to look at will be much appreciated.
