Re: Cub hydraulic noises, zings, and hoses jump
Posted by james rumph on February 24, 2008 at 10:42:49 from (24.192.116.205):
In Reply to: Cub hydraulic noises, zings, and hoses jump posted by mkirsch on February 24, 2008 at 08:23:10:
You need to go to cub.com and ask that question . I think it is air in the system gives the noise . The bleeding process for a normal system is .
1. Get tractor warm .
2. move hyd lift lever foward and back several times making sure you go full foward and full backward everytime.
3. Pull the lever all the way back and shut the motor off.
4. Now check fluid level.
This is right out of the book.
The pump is very easy to rebuild if your thinking it's that.
If your loosing hydr oil watch the oil level in the motor, it will rise.
The pump seals let the hydr oil into the crankcase when bad .
These things tend to be a pain. I had everything rebuilt by the dealer and it still wines ....
