Re: Front mounted shredder on M
Posted by Clarkbug on February 24, 2008 at 19:12:43 from (72.66.36.140):
In Reply to: Front mounted shredder on M posted by CenTexFarmall on February 23, 2008 at 19:24:16:
Here is one that I found looking around...
http://listserv.diytractor.com/Reposts/Farmall-sickle-bar/
Its not the same one as what I had in mind, but you can get the general idea from looking at it.
You could probably rig up a yoke of some sort using the frame rails to hold another U-joint as a pivot, and then take it from there to the shredders.
