Re: F656 D HS
Posted by Allan In NE on February 25, 2008 at 03:59:39 from (64.187.91.51):
In Reply to: F656 D HS posted by wolfe in tx on February 24, 2008 at 21:02:05:
Same thing happened to me a couple of years ago.
That tractor will hold all of 18 gallons of oil. Did you replace the filters too?
If the front pump is a little on the weak side, it might take a while to get all the air out of the system.
Don't think I'd even try to move it until the steering works insuring you have adequate oil to the charge pump also.
Just keep working that power steering until it takes a prime and then see if it will move.
Allan
third party image
