Posted by GordoSD on February 25, 2008 at 15:22:16 from (66.115.200.140):
In Reply to: H high idle speed posted by Alan Martinson on February 25, 2008 at 13:05:02:
When you lowered the carb to check it, you could have broken off one of the ears of the throttle shaft assembly. The original ones were metal. New replacements are plastic. Get the carb off again, check that both ears are in place. Check the screw that adjusts the trottle plate is just pushing the plate off the bore a tiny bit. Then reassemble, just insure your governor shaft is at the same position as the ceter of thethrottle shaft "ears". No air leak is going to cause a wide open throttle when you have the lever all down.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
