Re: WHEELS
Posted by F-400 on February 25, 2008 at 17:28:30 from (24.136.144.21):
In Reply to: WHEELS posted by F-400 on February 25, 2008 at 16:46:44:
WOULD U RUN TRACTOR WITH ONLY 1 KEY IN AXLES I USED PULL HANDLE TO ENSURE IT WAS TIGHT.MOSTLY USE H FOR BUSHHOGGING.I TRY HARD NEVER TO JERK TRACTOR.DON'T WANT TO HAVE TO FIND AXLE.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
