WHEELS
Posted by F-400 on February 25, 2008 at 16:46:44 from (24.136.144.21):
1943 H U KNOW THEY ARE TWO SLOTS ON AXLE THE CLAMP ITSELF HAS KEY MADE ON INSIDE TO FIT ONE SLOT ON AXLE. ON MY WHEEL THERE IS NOTHING THERE TO FIT SECOND SLOT.WAS THIS SUPPOSED TO BE MADE IN WHEEL OR WAS MADE LOOSE AND PUT IN SLOT BEFORE TIGHTEN UP THE CLAMP.ON MY 400 IT APPEARS THAT THE KEY IS SPOT WELDED TO WHEEL
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
