Re: Trouble 450 clutch
Posted by james3504 on February 25, 2008 at 18:15:19 from (70.109.15.32):
In Reply to: Trouble 450 clutch posted by james3504 on February 25, 2008 at 17:29:25:
Clutch Had a tollerance around the flywheel. Fingers are connecting to the p.plate and moving the fingers in when pedal is pushed down. I can see this through the inspection plate hole. New pilot bearing spun freely, installed correctly. Clutch will only fit one way because if its turned wrong the center hits the flywheel before disc contacts the surface. The only thing I'm not sure of is the shaft going into the pilot bearing, but you cant vissibly see this when your putting it back together, but clutch was centered with the p.plate and the disc and aligned correctly before I slid it back together.
