Posted by james3504 on February 25, 2008 at 17:29:25 from (70.109.15.32):
Got the tractor all back together. Trans shifts well w/ engine not running. I adjusted the clutch and ta by the book. 1" freeplay on clutch, when ya start tractor in neutral, clutch is disengaged as it should be, but when you try to shift into first it just grinds. I then adjusted it to the end of the rod in slow increments at a time. My results never changed, still grinding. I even used a cheat rod to make it longer, and my results were still the same except the clutch pedal bottomed out. I know this because from looking the inspection plate the three p.plate fingers were against the plate housing at their max. The only thing that I can think of is the flywheel friction surface will have to be machined to let the p.plate release. I"m I correct or not any suggestions would be great before I split again. Thanks
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
