Posted by LN on February 25, 2008 at 18:27:16 from (66.133.174.249):
In Reply to: Trouble 450 clutch posted by james3504 on February 25, 2008 at 17:29:25:
sounds like clutch is in backwards did this 2 wks ago on and H and one of my helpers thought clutch would only go one way but we were wrong ,you should be able to put tractor in gear (engine off) depress clutch pedal and be able to push tractor back and forth if you can't something is bound up ,if you look at clutch disk the side with the metal plate on will fit inside the flywheel , if you have the metal plate towards pressure plate it will be direct drive, the one I installed backwards bent the plate slightly had to modify it slightly to get it back in shape
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
