Re: H high idle speed
Posted by akb on February 26, 2008 at 00:33:19 from (71.220.116.231):
In Reply to: H high idle speed posted by Alan Martinson on February 25, 2008 at 13:05:02:
I had the same problem take the vent tube plate off the top of the governor and remove the pin from the clevis start it up and move the throttle shaft by hand if it will idle down check the tube for alignment or crud in tube or on shaft if moving by hand does nothing then the shaft tang is not between the 2 ears at carb or 1 is broke off.
let us know what you find
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
