Posted by Kevin Meier on February 26, 2008 at 05:56:37 from (65.166.132.170):
In Reply to: Trouble 450 clutch posted by james3504 on February 25, 2008 at 17:29:25:
First try setting your throw out bearing against the levers and see if the clutch will release. Don"t run the tractor for very long. If it doesn"t release check the lever height it should be 1 1/4" to 1 3/8" from the tip of the lever down to the backplate. If it"s at that spec split the tractor and check your flywheel step it should be 1.406 look over your disk and make sure it didn"t get pushed and bent when the tractor went back together.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
