Re: Trouble 450 clutch
Posted by JFavor on February 26, 2008 at 06:42:04 from (64.12.116.73):
In Reply to: Trouble 450 clutch posted by james3504 on February 25, 2008 at 17:29:25:
I would try this first.
Adjust the clutch pedal for the proper free play (1"). Have someone push the clutch pedal in & out while laying under it. You should be able to see it move. (Or you could prop the pedal in with a peice of wood). If the pressure plate is releasing you should be able to rotate the drive shaft (trans in neutral). May need a long screw driver or other tool to do it. If it won't rotate something is wrong with the clutch and you'll need to remove it.
