Re: U 6 block
Posted by Bob M on February 26, 2008 at 08:55:36 from (151.190.254.108):
In Reply to: U 6 block posted by LN on February 25, 2008 at 17:42:28:
I'm not 100% certain but I believe side frame clearance issues will prevent the original U6 starter from fitting when installed into an M tractor. Ie. you will need to use the original M starter with the transplanted engine.
Also unless the U6 and M flywheel/ring gear assemblies are not 100% identical I would recommend relocating the original M flywheel onto the transplanted U6 engine. (And if the U6 ring gear shows signs of wear now is the ideal time to install a new one - it'll be $40 well spent!)
