Re: M clutch specs
Posted by glennster on February 26, 2008 at 15:04:59 from (75.57.135.167):
In Reply to: Re: M clutch specs posted by 1 Dollar on February 26, 2008 at 14:52:50:
if you've got an 1/8 to the rivets you should be fine. the new disk has around 1/8-3/16 meat before the rivets. if you ever need to you can do the clutch thru the belly pump hole. for a dial caliper, i like the starretts, here is a link
