Super A hydraulic leak
Posted by Jim Bynum - Delaware on February 27, 2008 at 05:13:01 from (156.70.222.28):
I just overhauled my 1952 Super A hydraulic block and installed new o-rings and gaskets. I cleaned the block and parts after disassembling. I followed the I&T manual and some advice on this forum to complete the overhaul. After I put everything back together and a couple of days later, I noticed the control valves are leaking around the new boots. I installed the new o-rings on the control valve rod and used new hydraulic fluid to lube them before putting them on rod. I also rotated the rod as I installed to prevent damage to o-rings.
Anyone got any ideas what could have happened? I bought the kit from a CaseIH dealer so the o-rings looked okay to me plus I matched them up to old ones. They were a little difficult to stretch over the rod initially but went into the grooves okay.
Any advice would be appreciated.
thanks,
Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
