Posted by kippster on February 27, 2008 at 09:09:18 from (24.144.194.192):
In Reply to: Super A hydraulic leak posted by Jim Bynum - Delaware on February 27, 2008 at 05:13:01:
I've seen spool valves leak (not profuse amounts) for a while after a rebuild because of a tiny little bit of flash, (the rubber that is left from the molding process), being on the o-ring, and therefore letting a little bit of fluid to escape from the valve body. Once the flash wore off, the control valve didn't leak anymore.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
