There are only two places where you can get fuel into the crankcase on the 806. Either it has to come past the shaft seal or from unburned fuel from the injectors. If you got two additional inches in the crankcase in a half hour of running it is highly unlikely that faulty injectors are the problem. You would surely notice poor starting and excessive smoke if they were that bad. That leaves the shaft seal and pump adapter for the leak.
There is no seal inside the pump. The only seal for the fuel is the rear seal in the adapter housing. The side of the seal with the spring in the lip must face the pump. The front seal is installed with the lip forward and it is there to seal oil from getting into the pump. If the front seal were to be installed backwards it is unlikely that oil would actually leak into the pump since the fuel in the pump is under a slight pressure.
It is possible though unlikely that a porous housing is the cause. A defective housing would usually leak long before this. More likely causes would be a damaged seal, a seal installed backwards, a housing damaged when removing the old seal, or damage to the shaft.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
