Touch control - round?
Posted by tractorsam on February 28, 2008 at 17:03:47 from (71.7.203.35):
I got back at it tonight and I pulled out the remaining two check valve bushings with a tool the same as the in the photo a couple of pages along. It wouldn't shift my pressure regulator valve bushing though. I think I need a bigger bolt and larger hose. I also extracted all of the small allen headed pipe plugs. There was a lot of dirt behind some of them. I also pulled down the thermal relief valves and found some dirt in up there. It's all looking reasonable so far and I might even get it back together again :) tractorsam
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
