Re: 340 utility carb question
Posted by Janicholson on February 28, 2008 at 19:07:13 from (66.173.50.48):
In Reply to: 340 utility carb question posted by tooltime on February 28, 2008 at 18:57:36:
There are adjustments for high speed load condition running. The screws are sticking out of the carb. The load adjusting screw should be turned outward 1/4 turn at a time till it runs and responds to throttle well without the choke. The manual should indicate which screw. Most old sixties engine/tuneup/auto repair manuals will have good sections on carbs. Library, and a copy machine!!! JimN
