Re: 340 utility carb question
Posted by PaulW_NJ on February 29, 2008 at 03:59:42 from (71.187.55.168):
In Reply to: 340 utility carb question posted by Harold H on February 28, 2008 at 18:57:36:
tooltime said: (quoted from post at 01:35:59 02/29/08) thanks, Jim. Ill do some research on the carb and take it from there.
The actual rebuilding of a carb is pretty straightforward. Assuming you purchase the correct kit, it's just replacement of parts. The tricky parts are: examining, and correcting, the housing for possible air leaks, and if necessairy adjusting the float height.
And excellent reference for this, applicable for all carbs, is found over at the Farmall Cub website:
http://www.cleancomputes.com/Cub/Maintenance%20Tips%20and%20Techniques/Lurker%20Carl's%20Cub%20Carb%20Fixes/index.html
