Posted by Janicholson on February 29, 2008 at 09:02:08 from (199.17.6.122):
In Reply to: lift for pull type mower posted by John Koritansky on February 29, 2008 at 08:08:27:
That would work but be pretty clumsey to engineer and attach. Here is a second idea working off of your's. Using two IH old fashoned Liftall cylinders, attach one to the rock shaft, so the rock shaft pushes it in, connect the other to the mower to cause lift from pressure, and gravity lower. With the air bled out, it becomes a master and slave system that would be less complex. The cylinders may be pretty common. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
