lift for pull type mower
Posted by John Koritansky on February 29, 2008 at 08:08:27 from (143.206.81.33):
Here's an idea I had that I am tempted to try; and I wondered if anybody out there has made a similar atempt, with advice or maybe a warning. I bought a pull type sicle mower, a New Holland 450, with a hydraulic cylinder lift. I would like to pull it with my Farmall Super A. My idea is that, instead of installing a remote hydraulic on the tractor, I might operate the lift with a cable, attached to the rockshaft arms. The trick is in maintaining an equal distance from the lift arm on the mower to the point of attachment on the tractor when I turn. So, my idea is to run the cable from the lift arm on the mower through some sort of spool or pulley that would be located directly above the hitch pin that hitches the mower itself to the tractor. Then I would run the cable along the drawbar to a pulley and from there up to the rockshaft arm. Whadaya think? Anybody ever try this? Cool?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
