Re: lift for pull type mower
Posted by gene bender on February 29, 2008 at 10:51:04 from (67.55.226.69):
In Reply to: lift for pull type mower posted by John Koritansky on February 29, 2008 at 08:08:27:
You will need a pivot place where the hitch pin goes so as not to put pressure on the cable when turning. I would add a spring so the cable has slack to allow for turning and going thru low and high spots. It should work fine.
