H high idle speed - solved. Thanks
Posted by Alan Martinson on February 29, 2008 at 14:50:05 from (24.131.157.149):
Thanks to all of you who gave me tips on this high idle speed problem. I think it was a combination of things. I was a bit more careful putting the gov. throttle shaft into the carb. but I still could not get it to idle slow. I eventually followed governor adj. directions from the manual (and sent via email by Wayne). I had to adjust the low idle stop screw on the gov. control lever. and that allowed the throttle shaft to turn more - closing the carb. butterfly further. It works good now. I suppose I moved something when I removed the carb to install the new manifold. Thanks guys.
