Re: 1948 Super A Pulley
Posted by TractormanNC on February 29, 2008 at 17:52:58 from (209.42.180.10):
In Reply to: 1948 Super A Pulley posted by Ed S on February 29, 2008 at 11:30:39:
The H and M generators are the same size as the SA's but the pulleys are different. Sometime between the SA and the 130 production the part of the shaft where the pulley goes was shortened and the pulley was changed to match. Keep pulley and gen together and SA thru 6volt 140"s will fit.
