Re: 1948 Super A Pulley
Posted by Hugh MacKay on February 29, 2008 at 18:41:18 from (216.208.58.157):
In Reply to: Re: 1948 Super A Pulley posted by TractormanNC on February 29, 2008 at 17:52:58:
Leonard: I'm not exactly sure when but my 140 6 volt generator and pulley setup is quite different. My 140 has automotive type water pump on fan hub and a one belt system for crank, generator and fan-water pump. I believe that change occured in 1958.
My SA and 130 both had generators years ago and were identical. The reason I know, I changed both tractors to alternator and first looked at modifying those pullies to use on alternator. I'm certain the pullies were the same, as I had both of them at a machine shop, looking at the possibility of shortening the hub, so it would work on the alternator shaft. That was never done, switched to double V GM pulley. At one point I also had 130 generator on SA complete with 130 pulley. My 130 is within 800 of end of production.
