I'm not one that should give advice - but I just dealt with the same issue this afternoon using advice below from this forum. Good results so far. JimN posted this a few days ago: Simple and effective packing (if the needle is smooth) is Teflon tape twisted into a rope and wound around the shaft. Approximately the same amount of material is needed to make sure the packing is not too small allowing the packing nut to screw in all the way to thread bind. If too much is put in, the packing nut will not find threads to start on the needle base. Do not over tighten when assembling, the Teflon can be squeezed out the packing nut gap. This method takes less tension than the stock packing rope. Thin packing rope/twine is available at good plumbing supply houses as well. JimN
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
