Re: Farmall SM battery box problems
Posted by D Slater on March 02, 2008 at 04:25:24 from (72.65.144.81):
In Reply to: Farmall SM battery box problems posted by Mark Carey on March 01, 2008 at 20:57:46:
The box should have 2 slotes that go onto 2 special bolts with big heads that screw into top cover. They are used to slide box back and forth when accessing battery. What holds box is a steel strap that bolts under middle of box crosswise using 2 bolts into transmission cover housing. Its around 3/16 thick by 1 or 1-1/4 wide with bolt holes in each end to line up with battery box holes. It bolts on before box is installed.
