There is supposed to be a strap about 1 inch wide and about 12 inches long on top of the transmission cover that the battery box bolts to with two 3/8 in bolts. Many times these have been removed and thrown away and the bolt holes have filled up with crud. Also the battery box should have two slots in the bottom which slide on two special bolts that screw into the trans cover. HTH.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
