Probably need a bunch of machinable nickel rod also. Another thought---thread a nut on the stud after welding the stud in the trans case & weld around the nut on the trans case to "spread" the stress. However, this will lower the plate by the thickness of the nuts. Also, instead of having just a "shear factor" on the studs it will introduce more"pull-out" potential. Latest thoughts.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
