Re: International 454 brake problems (no brakes)
Posted by 495man on March 03, 2008 at 14:09:52 from (24.222.9.184):
In Reply to: International 454 brake problems (no brakes) posted by Red Mist on March 03, 2008 at 02:26:11:
The quick and easy way is to crack one bleed screw on the rear housing, and pump that side brake until only fluid comes out, tighten bleeder, then do other side.
Correct way is to put a hose from the bleed nipple directly into the hydraulic fill plug behind the fuel tank, and clamp off something under the dash by the master cylinder (memory is fuzzy)
