Re: Need C-123 help guys!!!!
Posted by Hugh MacKay on March 03, 2008 at 16:49:47 from (209.226.106.170):
In Reply to: Need C-123 help guys!!!! posted by Patrick Martin on March 03, 2008 at 11:35:02:
Patrick: Carburator or gas flow. Either you've got a gas flow restriction from tank or going into the carb. Could be the float or needle valve sticking. Can you save it from stalling with choke? I may not be right but those are worth checking.
Definitely not valves or coil. Valves wouldn't changes in a few min. Coil would be 30-45 min before it would fire up again. Could be points and condencer, they will sometimes act that way. Either that or gas flow.
