Re: Need C-123 help guys!!!!
Posted by El Toro on March 03, 2008 at 17:25:17 from (64.12.116.73):
In Reply to: Need C-123 help guys!!!! posted by Patrick Martin on March 03, 2008 at 11:35:02:
I would change the condenser. Never pull the head
when an engine quits, you need to use the process of elemination until you find the problem.
It could be stuck in 2 gears that's been mentioned. Did you have fire when it quit. You may have a weak coil. Pull a plug wire ASAP when it quits and check for fire to the plugs. If you have good fire you can rule out the coil. I don't think they even lap valves anymore at most auto machine shops. Hal
