Posted by Haas on March 03, 2008 at 18:40:48 from (12.65.60.54):
In Reply to: h water pump posted by TimWafer on March 03, 2008 at 15:18:15:
The design is such that the pump impeller shaft has only a torque load on it, no radial load. There is a separate mounting for the bearings that take the radial load, allowing them to be greased without any chance of water getting into the bearings. The grease seals are not exposed to the coolant. Modern water pumps usually have sealed bearings mounted on the pump impeller shaft. After a while the seals fail and then the bearings get water in there and also fail. How many automotive water pumps do you know that lasted 60 years like the one on your H???
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
