Re: Super A Final Drive and Woods Mower Bracket
Posted by eye4iron on March 04, 2008 at 06:30:19 from (70.253.178.39):
In Reply to: Re: Super A Final Drive and Woods Mower Bracket posted by gene bender on March 04, 2008 at 00:08:59:
Yes Gene you are correct. The oil should stay in the pans and if there is a leak at the out drive or a pan gasket you should notice it. I have however heard of the pans occasionally getting dented in on the bottom and then the gear rubs a small hole in the pan later on. It is possible to loose your fluid while mowing and not know it. I thought that an easy access to the fill plug would be a good idea but I didn't know if the 3/4 inch hole would hurt the Woods bracket structurally.
