Re: Super H Transmission sticking
Posted by Robert Haughn on March 04, 2008 at 08:19:05 from (142.167.69.225):
In Reply to: Re: Super H Transmission sticking posted by Janicholson on February 28, 2008 at 13:41:45:
The solution was right on. I was able to go at it this morning and found the shifter wore almost to a point. I welded , grinded (ground?), and re-assembled. WORKS A-1. Thanks for the help.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
