Re: f-12 primer /fuel return valve?
Posted by James Williams on March 04, 2008 at 10:50:50 from (74.46.212.159):
In Reply to: f-12 primer /fuel return valve? posted by drawbar on March 03, 2008 at 18:48:22:
Drawbar,The hood should be bolted over top of the valve,that way you can remove the hood without removing the valve
jimmy
