Re: f-12 primer /fuel return valve?
Posted by teddy52food on March 04, 2008 at 17:45:36 from (209.237.111.169):
In Reply to: Re: f-12 primer /fuel return valve? posted by James Williams on March 04, 2008 at 10:50:50:
You still can't get the hood off without un doing the lines unless you remove the steering shaft.
