504-2 said: (quoted from post at 20:01:01 03/03/08) I had a Massey service engineer tell me that if everything was set on a 1130 that the front wheels should just float across the ground.
my dad's farming stories from back in the day include the MM UTU's front hovering over the ground on a 4-14 JD pulltype til you pull the rope at the end. and a 3 ft blue flame above the muffler, or is it 4 ft now...
my dad and uncle have never plowed with draft control on. get stuck alot, overheat trannies (the ford 5000), etc.
seems to me every operator manual description of some type of draft system say that the arms will lift slightly in response to conditions and the tendency will be to transfer the load to the rear wheels. if the arms lift the implement so you can see it's lifted and the depth changes, then you are adjusted or set up wrong as it is over correcting. 90% of the 70s/earlier methods/manual quotes and what is encountered on this forum is for 2wd tractors with 70/30% rear favored weight, not 60/40 or 50/50 on an mfwd. and the equipment types we use today are not as simple as moldboard plowing (draft) vs mowers (position only). that leads to another issue; people using draft control too often when position is the correct choice. example: on land semi mounts should be used in position control only. other equipment types are mentioned ad nauseum in operators manuals both for tractors and the implements. in fact, the implement manual is the best resource to guide you whether you should use draft sensing or not. the tractor manual just gives you the basic examples, which may have exceptions because of your implement's design.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
