Measure the hole depth & if there is room for a slightly longer bolt, use one. Also, you may be able to find a "star" washer with either inside or outside teeth to use on the bolt instead of the helical spring lock washer that is on there now. As Jim N. suggested on the 460 draft control bolts---a little red Loc-tite on the threads will accomplish the same thing as a lockwasher plus tighten up any slop in the threads.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
