424 rear main bearing
Posted by jfloyd on March 05, 2008 at 09:03:48 from (70.106.27.38):
There is a little plate that blocks access to the rear main bearing bolts. Does anyone know how this comes out before I pry too hard on it? I"m worried that it may bolt from the flywheel side and the tractor would have to be broken to do this and to change the rear seal. Also, if anyone has the manual I need all the torque specs and if to know there is a sequence for tightening the head bolts.
Thanks
