Re: M Farmall Hyd's
Posted by Nebraska Kirk on March 05, 2008 at 15:52:20 from (98.16.163.30):
In Reply to: M Farmall Hyd's posted by Tarkwondo guy on March 05, 2008 at 15:05:03:
Most likely the seal on the pump needs to be replaced. You will have to drop the entire pump/resevoir assembly out of the tractor. Be forwarned, it is HEAVY! Then unscrew the end off of the pump shaft, it unscrews counterclockwise. You can then remove and replace the seal.
