M Farmall Hyd's
Posted by Tarkwondo guy on March 05, 2008 at 15:05:03 from (71.214.27.166):
Just got this 1941 M from the original owner and have been tuning it up in the shop. I noticed it leaks around the hydraulic pump gasket area while its just sitting. I did just check and fill the Hydraulic"s and noticed that it was leaking lots after the fill. Its slowed now but its still seeping some around the bolt area (which are tight). Is this a gasket problem and if so can I replace the gasket with out having to remove the pump? Thanks for the help.
