Prior to dismanteling it check and see if the worm gear mates to the center of the bolster gear.Normally you will find the worm is a little above center. If the thrust bearing looks OK you can put a correct size and thickness machine washer on top of the thrust bearing , that will center the gears again, I have found that 400's and 450's are the worst for this. I have also found recentering the gears will take a lot of the wobble out of the front wheels.
