Re: 6 volt cub farmall generator
Posted by Bob M on March 07, 2008 at 05:05:51 from (151.190.254.108):
In Reply to: 6 volt cub farmall generator posted by Gale Roberts on March 06, 2008 at 21:19:31:
Gale - The answer is "it depends":
- Open circuited (nothing connected to the ARM terminal), and with the FLD grounded, you can will see anywhere from about 15 - 25 volts between the ARM terminal and ground.
- However with the wiring connected normally, the FLD terminal grounded (ie. with the LHDB switch set at "H"), and with a fully charged battery, 7.5 - 8.0 volts will be the max.
Maximum current output is 12 - 14 amps depending on the setting of the 3rd brush and upon generator temperature (warmer generator = fewer amps)
Note - All the above assume the engine's running at maximum governed RPM...
