If you have good (unseated ) rings do this: Take it apart. Use a ball brush 250 grit glaze breaker on the cylinders. Use a slow drill and move at a brisk pace up and down the entire length of the bore (about 1 minute each) using 1/2 diesel, and 1/2 engine oil for solvent. Clean all parts, pre-lube the components with engine oil when putting it together. Make sure the rings are spaced at least 1/3 of the way around (staggered gaps). And go for it. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
