Posted by Jim Becker on March 07, 2008 at 20:57:39 from (71.170.123.240):
In Reply to: hows it work? posted by tn terry t on March 07, 2008 at 19:51:50:
That handle sets the sensitivity of the traction control. Equipment load pulls back on the lever at the bottom of #8, which causes forward movement of the lever on top of #8. Increaed load pulls forward on the rod #7. The rod pulls on the upper end of #9, working against a torsion bar. The extent that the upper end of #9 moves determines how much lift is applied at the cylinder to transfer weight from the implement onto the tractor tires. Moving the handle up raises the contact point of #7 on #9. The higher the contact point, the more leverage #7 has and the more the hitch will respond to the changes in load.
As far as how well it works, there have been 2 recent threads on that subject.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
